I just want to ask if anyone know how the filter works. What is the best setting for for filter in TMPGEnc. there is setting like range, time axis etc.
thanks you.
It kind of sounds like he's talking about the Noise Reduction filter, with Range, and Time Axis...
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
yea i'm talking about the noise reduction filter anyone know what is the best setting to get the max quality?
The Noise Reduction filter blurs the image to remove noise. The stronger you set the filter, the more it blurs the image. If my file has a lot (and I mean a lot) of noise I set it to Still Picture 85, Range 1, and Time Axis 85, then I also use the Sharpen Edge filter set at Horizontal 2, Vertical 4. Otherwise, if your source only has a little noise, the default setting of 20, 1, 20 will usually be OK. Just be sure to check the "High Quality Mode" box at the bottom of the Noise Reduction screen.
Zefram Cochrane
2073
Comment on Search Function
By smartel in forum FeedbackReplies: 4Last Post: 21st Jun 2011, 05:53 -
best DVD recorder filter & ATI AIW filter
By VCRcomp in forum RestorationReplies: 1Last Post: 27th Jan 2011, 18:27 -
Need slave function for capturing
By doggyjumper in forum Capturing and VCRReplies: 0Last Post: 25th Sep 2008, 12:06 -
Resume function
By powersmo in forum DVD & Blu-ray PlayersReplies: 5Last Post: 9th May 2008, 12:59 -
DVDShrink Incorrect Function
By pablo1999 in forum Authoring (DVD)Replies: 1Last Post: 25th Jun 2007, 13:42
