Has anyone tried Tmpgenc DVD Author? I find it very useful for both movies and episodes. It will take an episode and convert it to a .mpg file (and can edit it ) where you can create your own menu. You can do movies also. but the movie must be small enough to fit on a dvd-r. If not I use DVD Toolbox - www.dvdtoolbox.de to split it to 2 dvd's for big movies (over 5.5 gb) like lord of the rings to keep good quality. Otherwise I use dvd2one.![]()
Results 1 to 1 of 1
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07 -
TMPGEnc DVD author.
By netbuddy in forum Authoring (DVD)Replies: 20Last Post: 24th Aug 2007, 02:27
