I've painstakingly been trying to create chapters in Scenarist NT 2.0, but failed. How do I divide a title in say, 5 chapters using Scenarist? Do I needt to render 5 separate videofiles (with different audiofiles as well)? Or can Scenarist divide the track into chapters anyways?
Chazzie
No, you don't need to use 5 seperate video streams, you can simply add chapter points to one long MPEG stream. Just read the .pdf manual included in the installation of Scenarist, to learn how to do perform this procedure.
Arky ;o) -
I've read it, but I fail to understand how to do it... It doesn't work like it is described...
Did you really spend $20,000 for Scenarist? If you simply want to create chapters, many other $50 -$100 will do just that. Some will even tetect the scene chages for you. I use TMPGEnc Author and you can mnually insert chapters and create great working menus. You need to improt your video in MPG2 and then you creat the AUDIO and VIDEO_TS folders and burn them with nero to DVD using DVD/Video option.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
1. On the Track Editor tab (in the directory part), click on the movie.
2. In the bottom of the view section (“Scenes” area), position the marker at the approximate start of the new scene.
3. Click on the “New Scene” button or choose New | Scene.
4. Click (select) on the new scene in the “Scenes” area. Adjust the time in the Property Browser. Hit [Enter].
5. Repeat for all scenes. -
call your dealer -- scenarist comes with trainingOriginally Posted by chazzie
I bought it of a company that went out of buissness, and as far as I know there's no dealer anywhere near me.Originally Posted by BJ_M
Scenarist Mux Server Problem...Anyone?
By Thommers in forum Authoring (Blu-ray)Replies: 4Last Post: 11th Jun 2009, 13:06 -
Scenarist 4.3 subtitles problem
By paulspurrier in forum Authoring (Blu-ray)Replies: 1Last Post: 11th Jun 2009, 06:16 -
Has anyone used Sonic Scenarist or DVDit pro HD?
By jbandy1 in forum Authoring (Blu-ray)Replies: 16Last Post: 18th Feb 2009, 01:08 -
error when import subtitle in scenarist
By pcb in forum SubtitleReplies: 4Last Post: 17th Feb 2009, 05:38 -
Scenarist Menus
By nx01rules in forum Authoring (DVD)Replies: 5Last Post: 11th Nov 2008, 00:22
