Is VirtualDub only to be used with a DV capture card like an ATI, or has it been succesful with FireWire....I am trying to use a lower loss codec like HUFFYUV (allegedly) but I can't get it to work (VDub) with my DV cam...
Side note, if that can't work, any other choice besides the default Microsoft DV codec when capturing with Adobe Premier....
Results 1 to 9 of 9
I know Sony has a firewire driver for DV captures. What brand of camera are you using?
Hello. -
I have a JVC and a Samsung....looking to get more 'lossless' AVIs via FireWire....the default of Premiere is the Microft DV codec, and I think that is why I get non-professional looking MPEG2s after I render them in Vegas Video. Hoping to get HUFFYUV in there instead of Microsoft..I know you may say try TMPGENC frameserve, but I got the same results going from Premiere into TMPGENC, Vegas is just so much smarter and quicker than Premier...
You can not change the form of the data coming from a DV source. It is already compressed in the camera to DV.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
hi average joe,
maybe you can try and uninstall the MS DV codec first. Make sure you've
completely uninstalled it !!
Then, install any other DV code ie, pannasonic or mainconcept or canopus.
But, don't install more than one, else you'll probably confuse the DV apps
and have other issues.
Try the above and see what happens. Good luck
-vhelp -
How you I uninstall the MS DV codecs & install Mainconcept DV? Where can I get the same info for both DV & MPEG1/2...
Thanks -
@ starbuck..
try finding the direcoty where it's located and see if there is an un-install.
If not, then it's probably part of the OS install, and I'm not sure how to
do that.
You could also try looking under Control Panel, under
"Add/Remove programs" and see if MS DV codec is listed in their. If it is,
then just remove it. THEN, install the other DV codec you're interested in.
Good luck.
-vhelp
No audio decompressor could be found using VirtualDub
By dapster in forum Newbie / General discussionsReplies: 22Last Post: 6th Jun 2015, 04:25 -
VirtualDub - No audio decompressor could be found.
By kelemvor in forum Video ConversionReplies: 25Last Post: 24th Jan 2013, 16:36 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 11:19 -
Virtualdub error with DV files - Audio Samples not found in source
By kbehel in forum Video ConversionReplies: 4Last Post: 30th Mar 2008, 03:40 -
Virtualdub, 2pass - 1st pass statsfile not found
By kidcash in forum Newbie / General discussionsReplies: 1Last Post: 27th Dec 2007, 03:05
