I have tried now twice to convert a asf file to SVCD mpeg to burn. I am using the "SuperVideoCD (NTSC).mcf" template and the 2-pass VBR Varible Bitrate setting. I leave it running and some hours later I am out of virtual memory and the encoding process is going extremely slower than usual. I have encdoded tons of divx files into SVCD with the same settings with no problems. I am running Windows 2000 SP2 and TMPGEnc beta 12j, CORE version 1.77.113.
Do you use the "higest quality" setting?, if you do then try using High or normal quality.
It worked for me.
OH
ASF to MOV or MPEG4 problems using FFMPEGX for Mac
By Maverick101 in forum ffmpegX general discussionReplies: 3Last Post: 29th Sep 2011, 12:54 -
Overclocking, memory problems??
By HotDamn! in forum ComputerReplies: 26Last Post: 29th Apr 2010, 12:05 -
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 05:16 -
Memory Problems
By steve42069 in forum ComputerReplies: 5Last Post: 2nd Jan 2008, 11:10 -
TMPGEnc Error converting asf to MPG-2
By Caned_and_Able in forum Video ConversionReplies: 7Last Post: 6th Jun 2007, 10:07
