Hello all!
I just got ASUS TV Tuner and I'm a happy man.
There is strong noticeable difference in image quality if you
compare older BT8XX tuners. New Conexant chip rocks.
The problem that I have is the software. All available progs
like WinDVR2 PowerVCR2,etc offer limited Mpeg2 recording options.
I cannot turn off deinterlace(WinDVR),set bigger bitrate or insert
video filters.
PowerVCR for example even when u set 10000kbit/s, limits bitrate to
6000. WinDVR is very good but I noticed bitrate reduction to 10Mbit/s.
I am looking for soft that allows:
-capture full Mpeg2 files with a variety of codec options.
-insert filters (IVT telecine, deinterlace,sharpen)
-full variable and constant bitrate range in realtime
I haven't found such one so maybe somebody can help.
I'm tired of using TMPGEnc with extremely huge files for very simple
conversion that can be done in realtime.
Is there such thing like MPEG-2 encoder codec accesed through windows
interfeace like DivX??
Results 1 to 1 of 1
How to frameserve DVD/MPEG2/HDTV to an advanced video editor
By Baldrick in forum User guidesReplies: 55Last Post: 14th Feb 2010, 10:22 -
Need advanced framerate converter
By Xpenguin17 in forum EditingReplies: 17Last Post: 1st Jul 2009, 15:13 -
Capturing - to what format, DV or MPEG2.?
By Airjrdn in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 28th May 2008, 06:45 -
Advanced Video Editor?
By efb91 in forum EditingReplies: 0Last Post: 24th Dec 2007, 11:48 -
Software Recommendations for Capturing MPEG2
By scienceguy_4 in forum Capturing and VCRReplies: 7Last Post: 4th Oct 2007, 19:59
