I was wondering which program is the best for creating motion menus for SVCD's. I checked out Ulead DVD Workshop, but they only create the menu for DVD's only. So I was wondering if anyone can give me suggestions for any programs.
TSCV will make an alright motion menu using vcdimager and tmpg, but is complicated and buggy. You could also try making it in any editing program and encode with tmpg then author with VCDEasy.
I already tried TSCV and it did no go very well. I was wondering which BIG program (like Ulead or Adobe) is the best for SVCD?
Hands down for the best svcd creation is (IMO) WinOnCD 5... you can do anything on that program.... check it out, you need to author you menus with premeire or vegas video (any editor will work though) for best results...
You win some, and you lose some, and some get rained out... -
Pinnacle Studio 8 or Ulead DVD Workshop are two of the best consumer packages that have good motion menu functions.
Tygrus
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Slow-Motion editing program?
By Cipher5000 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 17th Nov 2011, 23:34 -
Motion Menu Buttons
By lapetite_66 in forum Authoring (DVD)Replies: 5Last Post: 29th Jul 2009, 15:45 -
Creating buttons on a motion menu
By jrd3263 in forum Authoring (DVD)Replies: 2Last Post: 16th Nov 2008, 16:13 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01
