Hy , is there a way to put more than one VCD or SVCD on one DVD and create a menu for it?
How do I do that? Got some single movies VCD and SVCD on DVD but thats not worth it...would be great though to have more movies on one DVD.
Any suggestions?
THX
First use www.svcd2dvdmpg.com and convert all vcds or svcd to compliant dvd mpeg
Then you can author all mpgs with menus with for example dvd moviefactory, tmpgenc dvd author or neodvd.
Wanted to put 4 CD's on one DVD
By happydog500 in forum AudioReplies: 2Last Post: 16th Sep 2011, 20:15 -
Help with Ripping audio from a VCD (2 discs) to put 1 DVD for a movie.
By shuya_nanahara in forum Newbie / General discussionsReplies: 7Last Post: 24th Jan 2009, 23:40 -
How do I put pictures on dvd?
By jbitakis in forum Newbie / General discussionsReplies: 2Last Post: 26th Dec 2008, 20:27 -
trying to put VCD files on a DVD with MyDVD Express
By curt1sw in forum Authoring (DVD)Replies: 7Last Post: 15th Nov 2007, 15:42 -
How can I Put PowerPoint on a DVD?
By jrhx in forum Authoring (DVD)Replies: 35Last Post: 26th Jun 2007, 14:07
