    Aug 2002
    Liverpool uk
    need help with this programme ezdv from canopus, when I try to capture analogue from the video part of the software I cannot see the whole display on my screen, on the bottom is supposed to be a tool bar with the record botton on it, in order to capture, I am supposed to click on this but it is not displayed on the screen it is sort of chopped off is it a problem with my display or the software.
    Nov 2002
    London, UK
    I don't know the answer but try the canopus forums at www.canopus.com
  3. Is the app size just bigger than your monitor resolution? Have you tried increasing the screen resolution from 800x600 to 1024x768 for instance?
    You probably thought of this. Just an idea.
    -dgraham
