Hi,
I have some problems with ISO Filenames, I want to put an application on the CD that requires a specific filename with lowercase characters and this is to my knowledge currently not possible with VCDEasy. Some other tools like Nero allow to write also filenames with lowercase characters. It would be a good idea to have the possibility for ISO level 2 and/or Joliet file system.
Any hint to overcome that problem is welcome!
Regards
Gerhard
Use VCDEasy to create your XML file.
Edit the XML with a text editor to re-introduce the lowercase of the files that are already listed in uppercase.
Use Vitualis' VCDImager GUI Tools app and burn using the lkVCDImager fork instead of the original VCDImager...this allows you to make a VCD where the ISO track is Level 2 vs. the usual Level 1.
HTH,
recover recycled photos with filenames??
By piano632 in forum ComputerReplies: 1Last Post: 3rd Dec 2011, 20:28 -
Pioneer DV-420V-K long filenames
By umniy2000 in forum DVD & Blu-ray PlayersReplies: 21Last Post: 7th Apr 2010, 14:20 -
Divx Player W/ Long Filenames?
By Qtrmeg in forum DVD & Blu-ray PlayersReplies: 4Last Post: 20th Feb 2010, 11:17 -
DVD player shortens avi filenames
By Ogilvy in forum Authoring (DVD)Replies: 2Last Post: 23rd Apr 2009, 21:24 -
How to find filenames when using tivodecode?
By Dougmeister in forum DVD & Blu-ray RecordersReplies: 0Last Post: 26th Nov 2008, 21:18
