I converted 2 avi files to mpg's and burned them on a DVD.
Work fine, except I wan to get rid of the Menu's and go directly
in to the movie
thanks
G
Click on options and choose Automatically start playing the first chapter. Then it should play the video directly when you insert it in your dvd player.
Or don't you want a menu at all??? -
I found it, was under the Options
Do not want the menu at all
Just start playing the movie
How to remove the language selection menu from BR Disc
By The-One in forum Authoring (Blu-ray)Replies: 21Last Post: 27th Apr 2014, 17:00 -
Panasonic DMR-EZ48VK How do I get into its hidden setup menu (Service Menu)
By RS456 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 14th Nov 2011, 02:50 -
How to remove the remove redundant tracks of *.ts?
By UMO in forum Newbie / General discussionsReplies: 6Last Post: 27th Feb 2010, 01:30 -
How to remove menu without re-rendering?
By Lippy Lipstick in forum Authoring (DVD)Replies: 5Last Post: 27th Jun 2009, 15:29 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36
