  1. I have a Cyberhome CH-DVD 402 and know that there is a problem with it when playing VCD/SVCD's which are encoded using TMPGEnc. However if a download an image of a film of the net, and burn it to CD, it plays in my player perfectly.
    My question is what encoder are people using that allow movies to play perfectly on my player?
    Cheers All
    MKAY
  2. Member DJRumpy's Avatar
    Dallas, Texas
    I would suspect your simply selecting the wrong settings in TMPGenc. As long as it is compliant with a format that your player supports, there is no reason it wouldn't play in your player.
    Impossible to see the future is. The Dark Side clouds everything...
