I don't know if anyone else has had problems but I have with the hardware and software in the subject area.
For some reason, at exactly 15 seconds into a burn with Nero (5.5.10.28) the computer just locks up completely. It doesn't do it with DVD-RWs.
But, I've since tried VSO's COPYTODVD software and had no problems at all. In fact, it even recorded at 2x despite the discs supposedly not being so.
Hi,
Try disable the DMA option of the DVDwriter and see if this helps you.
If you are in need for speed enable it before u use i.e a dvdripper.
Hope this helps you
Greetzzz Danny...Ever deleted a file and 5 minutes later banging your head on your desk for doing that...???
Rip the contents of home DVDs without it locking up the whole works?
By DB83 in forum MediaReplies: 3Last Post: 5th Dec 2010, 11:40 -
intel gma 4500HD and full HD video
By toupe in forum Newbie / General discussionsReplies: 1Last Post: 23rd Apr 2010, 12:11 -
Nero 9 Blu-Ray DVDs?
By orfajackson in forum Newbie / General discussionsReplies: 2Last Post: 27th Jul 2009, 03:14 -
Nero burning DVDs from the outside in?
By 2prfm.com in forum Authoring (DVD)Replies: 12Last Post: 19th Jun 2008, 22:47 -
Using nero to put 2 dvds onto 1
By pupa in forum Newbie / General discussionsReplies: 3Last Post: 9th May 2008, 23:14
