Hi, I need assistance, please...
I have an AVI file that won't open in TMPGEnc and haven't been able to find a solution for it from old posts and my own effort --- Anyway, basically TMPGEnc gives the typical "cannot open...unsupported" message when I try to open this file. It also does not open in Movie Factory. The file claims to be an AVI when I check it's properties but "AVIcodec" gives the following information regarding it: "...type ASF, one audio stream"
I have the Nimo Codec Pack installed and was able to capture the audio on the file with Goldwave but it's not opening for me to convert. Also the file does NOT open with the "ASFTools" program either.
Any suggestions? I'd appreciate them...
AVI is only a wrapper ... there are about 40-50 types of avi files , use gspot to see what it might be , some avi files can only be opened if you have a specific hardware card ..
Well, I can open the file outside of TMPG just fine using Windows Media Player --- and I've used Gspot with little success (unless I'm not understanding something) as I get a bunch of unsupported mess.
Any ideas? -
go into the vfapi priority settings in tmpgenc , in there you will see 2 avi readers (at least) , raise the opendml one to +3 and the other one to 0 . if this doesnt work -- reverse the above ..
vdub avi file opening problem
By naveenkrish in forum EditingReplies: 3Last Post: 8th Jun 2010, 11:54 -
Script redirects to website when opening a downloaded AVI file.
By B Nasty in forum Newbie / General discussionsReplies: 15Last Post: 5th May 2010, 05:01 -
TMPGenc crashes when opening avi
By Kromgol in forum Video ConversionReplies: 4Last Post: 19th Jul 2009, 09:03 -
Trouble opening avi in Tmpgenc 3.0 Express
By davexnet in forum Video ConversionReplies: 1Last Post: 11th Dec 2008, 11:07 -
having trouble opening an avi clip from a Canon ELPH SD600
By Webster in forum Video ConversionReplies: 7Last Post: 12th Aug 2007, 18:06
