  1. Hi all,
    Is there anyway to get a list of what application(s) have been installed on a certain PC and how much MB/GB they take up?
    thnks
    kas187
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Click Start: Control panel : Add/Remove Programs
  3. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    But a lot of times that doesn't include all of the programs.
  4. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Download regcleaner http://www.webattack.com/get/regcleaner.shtml . It's a great little free program, I use it all the time. Works with everything from 98 - XP.
    If you click on the Uninstall tab, clik on options, select show hidden programs, It will show everything.
    I use it all the time to clean up registry after Uninstalling apps.
    Never had a problem and highly recemend it on everybodys PC.
  5. Far too goddamn old now EddyH's Avatar
    Jan 2003
    Soul sucking suburbia! But a different part since I last logged on.
    all of the above plus eyes, pen, paper, and a long trawl thru all the folders. only way to be totally sure.
    -= She sez there's ants in the carpet, dirty little monsters! =-
    Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more!
