Hi all, here's a weird problem:. I've been using CCE in DVD2SVCD with no problems so far. Yesterday, I was doing a 4 pass VBR from an IFO/VOB folder and halfway thru got the following message:
"CCE Encoding Failed:Error: Video check-sum is different from that of previous pass. Source video data or time code may be different. Please check video tape or the information file."
Can anyone translate this into English for me? I use CCE in safe frameserving mode and DVD2SVCD runs on a P4. Haven't had this problem before either in AVI mode or DVD mode - any ideas?
TIA
JDC
OK. Heres ANOTHER weird thing: I just clicked ok on the CCE error message window (writing this message as its happening) and CCE started up again from where it stopped. Anyway, if anyone's had this problem, I'd appreciate a couple of lines on it. Thx.
Read DVD2SVCD's FAQ.
http://forum.doom9.org/showthread.php?s=&threadid=21859
Look at Q27. -
Anyone know why this happens? I installed the patch, but havent tried encoding again. What exactly does the patch do? Any downsides?
Why is the error even coming up? -
In between each pass CCE checks the .vaf file to ensure that it is the same file from the previous pass. If it appears different, CCE gives this error. Its really a pretty unimportant precaution because there really wouldn't be any reason for the .vaf to be different.
The reason people get this error with CCE is because of hardware limitations. Apparantly on some setups the temporary cache does not get deleted fast enough and basically CCE is using old data for its comparison.
The patch simply disables this checksum check entirely. As long as you don't go and try to swap out or move your .vaf file in between passes, there is no way this patch could have any detrimental effects. So no, there aren't any downsides. Anyone who uses CCE for multipass VBR should go ahead and install this patch first.
AVCHD - Converting video pass 1: Errorcode: 0x0401,Error occured
By time2innov8 in forum Authoring (Blu-ray)Replies: 10Last Post: 19th Jan 2014, 14:20 -
MP4 will not play after I edit metadata (internal checksum?)
By vodpod in forum EditingReplies: 13Last Post: 29th Jan 2012, 00:12 -
MD5 checksum
By Soixante in forum ComputerReplies: 6Last Post: 27th Dec 2011, 08:35 -
Two Pass encoding error
By iSherbiny in forum EditingReplies: 0Last Post: 10th Jan 2010, 06:14 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16
