Hi, have put 2 dvd films (Disney), successfully onto 1 dvdr, would like to create some kind of menu where the main screen, when dvd inserted into dvd player, gives u the name of the 2 films that are on the dvdr, from there i would like to b able to select 1st, or 2nd film, from just a simple background picture on boot up screen of both films that r on the dvdr, can n e body please give me a tutorial on how to do this.
Many Many Thanx (To the 1 who can help me)
Max
hmmmmm i take it you movies are in mpeg format so use something like ulead dvd factory or maestro then you can create menus so authoring forum
No, my movies have been taken in through DVD Decryptor, then reduced in size to 2.1gig each, they r in VIDEO_TS folder as Vob's etc. Tried posting this message in Authoring Forum, but for some reason it was moved here.
Many Thanx
max -
hmmm i dont know of a way of doing this sorry not without making them in to mpegs or d2v files maybe some 1 else could shed some light
I've done couple of disney movie backups on 1 dvdr.. ie. toystory, toy story 2..
After I compressed them to the 2.2 gig each using dvd2one I demux the streams using vobedit program then created a menu using dvd menu studio program ( took snap shots of both movies using windvd player added menu texts in dvd menu studio) the output .psd files were inported in to maestro and burn... looks great... -
In MAGIX video deLuxe 2.0, one works with “disk projects”, “movies” and “chapters”. For quick, intuitive handling, it’s important to clarify the difference between all three terms and to become familiar with the hierarchy in which they must be organized.
Disk project
A disk project includes everything that you want to accommodate on your CD or DVD. Usually, that will be one or more movies (including the appropriate menu structures). Disk projects can be saved on the fixed disk as a ”DIP” file and can later be re-loaded in order to edit movies further.
Movie
Every “movie” can be divided up into as many “chapters” as you wish.
Every “movie” can be saved on the fixed disk as an MVD file. Such files contain chapters, effects settings, cutting markers, sound material – basically, the whole movie. The title of the disk project is automatically positioned in the uppermost part of the Selection menu hierarchy, which is also burned onto disk.
Chapter
A “Chapter” is a freely definable range (a sequence, an episode, a passage, a take) within a movie. As mentioned above, you can picture it as a roll of film within a larger film box. If a movie is not divided into chapters, in theory it is made up of just one chapter. In such a case, the Filmbox contains just “one film roll”.
The breakdown of a movie into chapters is performed either automatically through scene recognition, or manually through cutting “by hand”. A movie’s chapter land automatically in the Selection menu as a secondary “sub menu” entry.
In order to achieve meaningful chapter partitioning in the selection menu, each film must be divided into chapters. This is done in the video editor with the assistance of the edit menu. Place the start marker where you want a new chapter to be set, and select the “
chapter marker” option. The blue chapter markers appear in the timeline above and are movable via drag & drop or can be deleted via the “Delete (all) chapter markers” menu option.
In a nutshell: “disk projects” contain “movies”, “movies” contain “chapters”. Movies and chapters within a disk project appear later as menu entries on the CD or DVD. -
hi mushroom..you say you now have two movie(VIDEO_TS) files approx 2GB each...now use TMPGEnc DVD Author..just released on trial...and import DVD Video (VIDEO_TS folder) directly...the same for the second movie..create menu...then output to folder and disc...nice piece of software
Hi mememe77,
I got the same issue. Please give more details how to do 2 movies on i dvdr with a menu.
Thanks,
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
Recreate DVDR menu or edit code?
By ScannerWA in forum Authoring (DVD)Replies: 4Last Post: 24th Oct 2008, 15:54 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 17:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 18:14
