Just wondering how much a WAV file is compressed by if you change it to AC3. I am new to this and have encoded 1 minute of AVI to MPEG2 and the resulting WAV file is 10.6MB which seems big for 1 minute.
How much do you think this file would be reduced with AC3?
yes, thats probably about right,
usually, a two-hour movie is about
a 1000 mb or less, using v-dub, you
can use besweet to convert to ac3
and it should come out to 100-300mb
depends on setting you use i guess....
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 15:26 -
Encoding wav file to ac3 specification
By gouletjo in forum Authoring (DVD)Replies: 1Last Post: 15th Feb 2010, 22:40 -
5.1 Wav to AC3
By markjwiggins in forum ffmpegX general discussionReplies: 0Last Post: 21st Dec 2007, 14:44 -
Hiss removal from AC3 file without converting it to WAV?
By Turbo Sensonic in forum AudioReplies: 21Last Post: 7th Jul 2007, 06:18
