I`ve been playing a little trying to convert my film collection into DVDs.
I was recomended a program called NeoDVD which takes any file and pops out a load of Vobs ready to burn to a DVD - excellent!!
Except that a typical XVid film comes out at over 5Gb![]()
Now I have also "aquired" *ahem* the 1st Series of both CSI and 24, and would like to put these onto a DVD, but using this program mean 2 episodes per DVD - this can`t be right but I don`t have the knowledge to know why.
I also tried another program which reported 35 hours for a 700Mb movie to convert to DVD Compliant PAL mpeg clip on my system:
P4 2.53
512Mb DDR400 RAM
200Gb ATA133 HD Space
etc etc
Is this time right - does it really take this long per film?
My other option is to simply burn the avi files onto a DVD and watch them in my XBox, but this is last resort really.
Cheers guys.
okay, so check your divx's for correct frame rates, modify audio and video frames if necesary to comply with pal or ntsc frame rates, do not let the encoder do this. all a encode does is pad missing frames with dupilicate frames giving a staggered look especially on pan scans! use cbr mpeg 2 @3500kbps setting in tmpgenc and you should 3 good quality episodes to a dvd. if you have the time a vbr setting @3000kbps will allow you to keep good quality and get 4 episodes on 1 disk!
good luck -
Use the guides here :
Convert to DVD : https://www.videohelp.com/tmpgencdvd.htm
Author to DVD : http://www.dvd2dvdr.com
or here http://clik.to/divx2dvdr
Thay all contain information which should be helpful to you.
DJ
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
DVD to AVI (done) to Divx or xvid
By Grumpy_one in forum DVD RippingReplies: 3Last Post: 16th Mar 2009, 18:28 -
Best DVD to DivX / Xvid avi
By spidey in forum DVD RippingReplies: 6Last Post: 3rd Jul 2008, 15:20 -
What's best to burn to DVD: XVID, DIVX, AVI?
By peterj in forum Authoring (DVD)Replies: 3Last Post: 17th Jan 2008, 08:35 -
I need to convert dvd into avi!not xvid or divx!
By picky2112 in forum DVD RippingReplies: 5Last Post: 6th Jul 2007, 03:22
