i finally found a dvd movie that i have that is close to 4.7 gb
that that is like 5.7 gbs which is the movie Panic Room
Now i need to know how the hell can i remove files inorder to make it smaller in order to burn it to the 4.7gb DVD-R.
Is that even possible - even if i don't know what to remove!
you can try a program like DVD2One or DVDShrink to take out things you don't want like alternate audio tracks, then compress what is left to fit on the target medium.
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
picture size difference after transcoding (TMPGenc 2.5)
By jakewoodblues in forum Video ConversionReplies: 12Last Post: 27th Apr 2010, 20:57 -
Large size difference in mov and mpg, no apparent loss of quality.
By prioryjim in forum Video ConversionReplies: 3Last Post: 20th Dec 2009, 09:19 -
Adobe Premiere. Difference between frame size and scaling?
By vid83 in forum EditingReplies: 4Last Post: 13th Dec 2008, 21:57 -
Difference in size when using two different prograns to convert XVid to DVD
By perfection in forum Newbie / General discussionsReplies: 5Last Post: 29th May 2008, 12:43
