I kno u guys get this question a lot, but ive ran out of ideas. Ive searched the forum and done what u guys have instructed to do. when i try to decompress audio with full prosesing mode, I GET:no audio decompressor can be found to decompress the source audio format.
ive ran gspot22 it says i have all the codecs video and audio. the codec name is ac3 (0x2000) Dolby Laboratories, Inc. and the codec stat is AC3 from AVI Xform and cyberlink audio decoder which is misconfiged. PLEASE help me. here a link of the detailed info from gspot
http://www.imagestation.com/mypictures/inbox/view.html?url=http://www.imagestation.com...&id=4230080142
thx for help
vdub wont convert ac3 or extract the wav.
extract the wav with http://www.divx-digest.com/software/avi2wav.html
rename the wav extention to ac3 then convert it to wav or mp3 with HeadAC3he.
if you want the avi to have mp3 audio,just join the mp3 and avi.
if your converting to (s)vcd take the final wav and add it to TMPGEnc -
Goldwave will extract AC3 audio and convert to wav all at once. Just load the avi in Goldwave then save.
VDub Problem
By heygurl in forum SubtitleReplies: 8Last Post: 9th Dec 2010, 18:38 -
Best Vdub deinterlacer?
By brassplyer in forum RestorationReplies: 14Last Post: 25th Apr 2010, 21:50 -
VDub Help..!!
By scratchlikeme in forum Newbie / General discussionsReplies: 3Last Post: 17th Nov 2009, 06:40 -
vdub -> wmv?
By zapster in forum EditingReplies: 10Last Post: 17th May 2008, 20:16 -
Vdub problem
By RR420 in forum Capturing and VCRReplies: 0Last Post: 8th Mar 2008, 13:43
