My first captures/encodings were done with no noise reduction used...they would have needed it that's for sure..and the latest I've done with Tmpgenc's noise reduction have been superb in comparison to my "newbie" conversions....so is it wise to perform noise reduction to something that is already encoded into mpg..or should I just re-capture the tapes to avi and re-encode using noise reduction ?
To my knowledge...applying a NR filter would mean you must re-encode the video also...and re-encoding means quality loss.
You can seperate the video and audio. Then convert the audio to wav.
Then edit the wav using a good audio program.
Then convert back to mp2 and re-mulitplex with the video.
It's better to sort out why you are getting poor audio in the first place tho.
Fozzee -
Think your probably right
It's getting late, need to read properly
Fozzee
need method for video noise reduction
By codemaster in forum EditingReplies: 2Last Post: 1st Jan 2012, 18:10 -
Digital noise reduction - a warning
By Quasipal in forum RestorationReplies: 4Last Post: 7th Nov 2010, 14:16 -
Speaking of noise reduction, what is this?
By takearushfan in forum RestorationReplies: 11Last Post: 5th May 2010, 22:14 -
Noise reduction
By Geevim in forum RestorationReplies: 3Last Post: 5th Nov 2007, 07:23 -
Video Noise Reduction ----> H E L P
By wxyz in forum DVD RippingReplies: 14Last Post: 21st Jun 2007, 20:22
Fozze....I know the late nights you speak of.
