is there abit of software to put at the front of your dvd so you can watch the start or middle or jump to the last scene .as the dvds ive been doing just play from the start .
Be helpful if you let people know what software you're using and such.
Most authoring programs allow you to add chapters to your project which would allow you to jump through it. Most also will let you create a chapter menu which will let you jump to a particular scene by clicking a link from the menu.korth -
im using ulead dvd movie factory 2 . what im trying to do is at start of dvd have the picture of the movie with menus on top of it. hope that makes sense.
EASY just see what format the backgound are and size, then make one in Photoshop and import it. Then just add you Chapter point on top, thats it!
Keep going till you get it right!!!
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 03:44 -
Better Menus
By clinging2thecross in forum Authoring (DVD)Replies: 3Last Post: 13th May 2011, 06:10 -
Menus folders or sub-menus
By GymDad in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 9th Nov 2008, 08:43 -
Magix Movie Edit Pro Menus and Sub-menus
By gayclarke in forum Authoring (DVD)Replies: 8Last Post: 11th Aug 2007, 11:07 -
Menus
By mingul in forum Authoring (DVD)Replies: 4Last Post: 19th May 2007, 07:42
