Hello all,
I'm fairly new to the DVD/VCD scene so be gentle with me. Here is my problem.
I ripped one of my DVD's using DVDBackup 1.3 to my HD. seemed to work well. Then I used DTOX to squeeze it down to a DVD-R, but 75% through the process i get an error saying something like - Decryption Error, need to decrypt file.
Then I tested the VIDEO_TS folder using my Apple DVD Player and it seemed to work fine.
What am I doing wrong and what is the best Decryption software I should be using?
Preston
It may be that you didn't remove the Region Control code - try
Change Region Control Coding
New Region: Region Free
hth -
I had that happen once before. I simply used OSeX to rip the DVD instead of DVDBackup and it worked fine.
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 15:59 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:10 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
