Ok, I have a problem. I used to encode movies all the time with TMPG only. Did not need any programs like Virtual Dub, etc. However, I am unsure of the best settings to use when encoding TMD releases in .avi format. The encode process goes without error, however, when I attempt to play it on my DVD it is jerky (both picture and sound). It seems most of the avi's are the following:
352x288, 56kbps bitrate, mpeg layer 3, 12 frames per second, 44kbps data rate, 24 bit sample size, and ms-mpeg4 v3 video compression.
The others are the same for everything except they are 14 frames per second. Please help
Results 1 to 1 of 1
Jerky playback
By hi2shy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 30th Nov 2010, 17:44 -
Jerky Playback
By electrowiz in forum Video ConversionReplies: 1Last Post: 25th Aug 2010, 17:16 -
jerky tmpg
By devdev in forum Authoring (DVD)Replies: 6Last Post: 12th Aug 2010, 09:14 -
jerky playback
By VOYAGER2009 in forum Video ConversionReplies: 19Last Post: 22nd Feb 2010, 06:27 -
Jerky playback on TV from PC using TV Out
By digidude in forum Software PlayingReplies: 0Last Post: 30th Dec 2008, 18:26
