What is the Scandata.dat file??
Should i include it?
What should it contain?
Im using Nero to burn SVCDs.
Any help appreciated.
Just make a file using Wordpad or other text editor.
The file should contain the following:
SCAN_VCD
These characters only, no carriage return or line feed
characters after these 8 letters. The file should be
saved as SCANDATA.DAT and it should be 8 bytes. Some may argue this should be lower case, but it would not work for me with my Apex 600a player unless it was upper. You may also need to rename it if it is saved as scandata.dat.txt
You need to drag this file into the EXT folder when you are producing an SVCD with Nero 5.5.3.5. 5.5.4.0 (the latest version) will not let you replace the SCANDATA.DAT file it is using already (which doesn't do a damn thing by the way,
at least from my experiences with it).
Svcd structure
By nichok72 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th Aug 2008, 16:03 -
SVCD edit
By monarols in forum Video ConversionReplies: 3Last Post: 15th Jul 2008, 17:48 -
Svcd Burning
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 16th Apr 2008, 08:25 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18 -
avi2dvd scandata error...
By Crapozo in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jun 2007, 05:33
