  1. FLOYD JOHNSON REPORTED ON 2001-04-27 THAT YOU COULD BURN A
    SCANDATA.DAT FILE TO EXT USING NERO SVCD. I WOULD LIKE TO KNOW WHAT THE PROCESS FOR DOING THIS IS. I COULD NOT GET IT TO BURN AS IT WAS NOT A SVCD COMPLINENT FILE.
    May 2001
    London, UK - Bonn, Germany
    If you do a search in the forum - keyword SCANDATA.DAT, there are many suggestions how to do this.
    If you still are encountering problems on making and burning this file, I would suggest you use the simple (in tools downloadable) program called VCDImagerGUI. This will create an "image file" which you can then easily burn in Nero.
