I have trouble ripping a DVD so that subtitles will be included in the .VOB file on my HDD ie: i run the .vob file and the subtitles are already there (so that i dont have to turn them on and i cant turn them off).
I can rip a dvd so that it make a separate file which has the subs in there, but i dont know what program to use to combine them with the VCD/SVCD mpg file.
Ive tryed using DVDx 2.2 which lets u rip a DVD to svcd or vcd and have the subtitles included but this program often runs into audio/video sync problems, and it wount tell me unless i stop the encoding, which equals a big waste of time. On avarage a DVD which is 2 hours long will take me a litte over 2 hours to encode.
If you know of a program that i can use to combine the subs with the vcd/svcd mpg file, or directly with the dvd's .vob file all my problems are solved, oh and if u know of a guide, that would also be helpful, it would save me some trial and error trying to figure it out.
Thanks for your help, its greatly appreciated.
--NeoGearX--
Try this guide.
I use MPG2MPS program.
but if ur trying to burn the subs into the video, im not sure.
Sure you could use Vdub frameserver to tmpgenc.
AVIAddXSubs Question: PS3 can't read Japanese Subs
By NikoNikoNeko in forum SubtitleReplies: 3Last Post: 20th Oct 2010, 21:21 -
Samsung HomeTheatre HT-TX22 won't read Subs!
By assi91 in forum Newbie / General discussionsReplies: 0Last Post: 7th May 2010, 03:41 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 16th Jun 2007, 23:04 -
VCD to DVD with subs - subpictures below video-image - Help?!
By nbarzgar in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 16th Jun 2007, 10:44 -
VCD to DVD with subtitles in DVDlab Pro - subs 'disappear'...
By nbarzgar in forum Authoring (DVD)Replies: 0Last Post: 11th Jun 2007, 10:16
