I have a p3 1g computer with windows 2000 on it with a 30g
5400 hard drive with 256 megs of ram. Is my hard drive fast enough to capture movies on it? Im using ulead msp as my capturing software.
Sure, but 30GB is fairly small, so you'll want to use some compression codec to save space. Losses codecs like huffyuv are the most popular.
IMHO, 5400 are not fast enough for sustained long captures. I have 7200 IBM and it does the job without dropping frames. 2GBs of space is required about 9 minutes of video. Therefore 30GBs is about 45 minutes of video.
Other important points, use a separate HD for your applications/system and second HD for your AV. Finally, your HD used for AV should be format NTFS if you plan on capturing pass 4GBs with W2K. -
I have 2 h/d's on two different system's windows me is on my 40g 7200hd and windows 2000 is on my 30g 5400.. I captured a 1 hour movie from my camcorder to my 30g h/d it took up 12g's of space. I didn't drop any frame's but my h/d led light was flashing all the time..
I have a Dual Pentium 3 1 Ghz Geforce2 Ultra 2 HD 10GB 7,2000 in Raid 0 ans 2 40gb 7,2000 in Raid 0 for Video Capture and 2 40gb 7,2000 for storage all format whit NTFS. sound blaster live X-Gamer Win-TV FM W/Remote and WinXP pro no problems whit capture use raid 0 for capture and you see the big difference .
Feel my Power Flaming Black Dragon Wave!!!!
How fast is enough?
By ahhaa in forum ComputerReplies: 6Last Post: 7th Feb 2009, 01:58 -
Just how fast is Firefox 3?
By ahhaa in forum ComputerReplies: 4Last Post: 20th May 2008, 11:07 -
Video is going too fast
By wiksten in forum Capturing and VCRReplies: 0Last Post: 3rd Apr 2008, 14:27 -
Divx won't fast forward fast! What's wrong?
By Hank Kinsley in forum Newbie / General discussionsReplies: 8Last Post: 23rd Jul 2007, 19:49 -
.wmv movie file couldn't fast forward/fast seek?
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 20:43
