hi!
sorry if this was asked before...
is there a way you can set tmpgenc to automatically skip the errors that show up during the encoding( if you press ok the encoding continues), like: "Error 433 1462" ???
i guess the avi that i make the svcds from is bad, so if i cannot skip errors how can i repair it quickly?
thanx!
oh, i forgot: the movie plays fine, but i get errors when i encode it and its a divx pro 5.0.3 codec
You should scan and remove bad frames with Virtualdub before doing the encoding. You can get all kinds of problems if you don't. If you do a forum search or look in the guides you'll find lots of information.
Commercial Skip
By Montani304 in forum Newbie / General discussionsReplies: 1Last Post: 1st Aug 2011, 08:54 -
TMPGEnc AW4 Chapter Head Skip button NOT working
By BobAchgill in forum Authoring (DVD)Replies: 0Last Post: 23rd Jun 2010, 10:14 -
TMPGEnc Xpress 4.0 stuttering conversion errors
By CasanovaFly in forum Video ConversionReplies: 2Last Post: 26th Nov 2009, 16:32 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 17:02 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 11:53
