ok i'm trying to convert an audio sample from an avi. reading the instructions on the webpage it says i can convert it to mp3 to save space ? is it better if i keep the audio in wav or is mp3 ok ?
Well, it depends what you shall do with the audio file. If you are going to burn it as a cd audio use wav. If you are just going to have it on your computer use mp3(use a higher bitrate for higher quality).
DVD to WAV/MP3
By Baldrick in forum AudioReplies: 38Last Post: 10th Oct 2020, 04:47 -
MP3 or WAV?
By Charmer in forum AudioReplies: 4Last Post: 6th Aug 2009, 19:20 -
mp3 to wav
By stewart2000 in forum AudioReplies: 8Last Post: 27th Sep 2008, 06:12 -
Midi to Wav/MP3
By ks47 in forum AudioReplies: 11Last Post: 30th Sep 2007, 23:14 -
How can i change an mp3 to a wav?
By pondleaping in forum AudioReplies: 7Last Post: 28th Jul 2007, 03:09
