Hi Gurus,
I have an AC3 at 48.000, 5.1 ch at 384 kbps.
I'd like to resample it to an AC3 at 44.100, 5.1 ch in order to mux it with a SVCD file.
How can I do it ?
SVCD do not support ac3. But you could make a "XSVCD" that may work on some dvd players, but then I would not convert the audio to 44 khz cause 48 khz is already supported by all dvd players.
So hereby the story,
I have a divx film in ac3. I'd like to decode it in svcd format and preserve the 5.1 channels.
I used Virtualdub to extract the video (avi) and the audio file (ac3).
I converted the video to SVCD (from avi to mpeg with TMPGenc)).
I muxed the mpeg with ac3 with avi2mpg2.
But on my home dvd+home theater system I can only see the video.
I think that the problem is the sample of the audio file.
Any suggestion ?
Thanks -
First make sure that you are playing the right audio track you should be able to select audio channels using your DVD remote.
If still you hear no audio your player isnt going to play AC3.
If you want SVCD with 5.1 Surround you need to convert the AC3 to Mp2
using hypercube Transcoder in the download section there is also a guide to making SVCD with 5.1 surround in the guides section.
AC3 muxed with SVCD wont work you can try resampling to 48khz with besweet in the download section but you'd be better off using hypercube.
I've never tried to use an AC3 when making SVCD i always convert to mp2 5.1 as it is compatible with SVCD. Dont get mixed up with thinking that SVCD is similar to DVD frame size and audio are not compatible with DVD. -
Yes but CVD is and that is 352x576 and svcd!
Keep going till you get it right!!!
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23 -
MPEG4-AVC (H264) + AC3 -> Divx + AC3?
By thomas_fogh in forum Video ConversionReplies: 12Last Post: 1st Nov 2008, 21:25 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 08:06
