I'm currently learning how to authorize DVD using ulead movie factory 2.. but the program seem to hate 23.976fps VCD mpg and reconvert the video to NTSC which is 29.97fps.. but it takes wayyyyyyyy too long... i want to know if there are other possible solution of authorizing 23.976 VCD MPG onto dvd..
or is there possibility to convert 23fps to 29 so the program will accept the file and not do all those re conversion??
please help... i'm very desprate to find answer.. i try search on guide but unable to find a definate answer..
have u checked the box under project settings .......(Select Do no convert compliant MPEG files).Or it will always reencode the mpg file.There is a guide on this subject https://www.videohelp.com/vcddvdr.
mpeg1 23,976fps is not supported on dvd so you must reconvert. You could try author with ifoedit instead(it does not check for dvd compliant) and make a "xdvd" that may work on some dvd players.
I've try Ifoedit.. and the audio still seem to get out of sync with the video... any more solutions??
To synchronize 29,970 audio fps for 23.976 fps
By DruidCtba in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2009, 13:01 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
Converting 23.976 fps to 29.97 fps
By wasimismail in forum Video ConversionReplies: 8Last Post: 14th May 2008, 19:26 -
Best quality telecine method for 23.976 -> 29.97fps
By DRP in forum Video ConversionReplies: 3Last Post: 11th May 2008, 09:37 -
Difference?? 23,976 pics/s or 29,976 fps
By twanbaten in forum Authoring (DVD)Replies: 1Last Post: 6th Nov 2007, 12:29
