Just bought the unit. Instruction says widescreen record only on DV-RAM and pan-and-scan on DV-R. Can this be true? Anyway around this?
Hello
Actually it WILL record a 16x9 input but the DVD-R will be flagged as having a 4:3 source. What that means is when you play the DVD on a 4:3 television the DVD player will not know that the disc is 16x9 and will not resize the image, making everyone very tall and skinny!
However, if you watch it on a 16x9 widescreen television, then it will appear normal. This applies to both a true 16x9 sized display as well as a 4:3 TV that has a 16x9 compression mode (not too many though have that feature).
If you have a DVD recordable drive on your computer you could rip the DVD-R to your computer's HDD with DVD Decrypter using FILE MODE and make sure you select ALL FILES. Then you can edit the IFO file and change the 4:3 flag to 16x9 (there are programs that allow you to do that such as IFOEdit). You can then use a program called ImgTools (the "classic" version seems to work best) to turn your ripped DVD files into a disc image. Then burn the image to a DVD-R or DVD+R (whatever your recordable drive in the computer is) using DVD Decrypter.
Please note that ALL of that software is freeware/shareware so cost is no biggie ... assuming you have a DVD recordable on the computer.
Anyways, as you can imagine, changing the FLAG to 16x9 will correct playback on a 4:3 television.
I know this software can either be downloaded from this site or the doom9 website. I think doom9 also has a guide for IFOEdit (which I've never used but if all you need to do is change that flag from 4:3 to 16:9 it can't be all that hard).
- John "FulciLives" Coleman
PLEASE NOTE
This is only if the source is a 16x9 enhanced source. If the source is a simple 4:3 image that is widescreen then you won't have any trouble with it being widescreen. -
Wow, FulciLives, thanks so much! Makes me feel better that I didn't mess up and bought the wrong recorder. Will try those tools you mentioned. Thanks again.
DMR-EZ27 - can I record HD/widescreen without the result being stretched?
By SVTarHeel in forum Newbie / General discussionsReplies: 0Last Post: 25th Aug 2009, 00:34 -
Panasonic DMR E50/E55 drive replacement
By zzucru in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Oct 2008, 14:09 -
If I record in Widescreen 16:9, how will a DVD play on a Standard 4:3 TV?
By syberkill in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 3rd Jun 2008, 11:03 -
Widescreen playback on Panasonic plasma
By ozkelron in forum Software PlayingReplies: 7Last Post: 12th Feb 2008, 17:26 -
looking to replace a panasonic DMR -E50 any ideas?
By edmond in forum DVD & Blu-ray RecordersReplies: 4Last Post: 27th Oct 2007, 13:34
