  1. Hi,
    I've just installed my long awaited DRU500AX 2.0c
    It's on secondary master on a ASUS P4S8X, 512mb RAM, P4 2.4, ATI RADEON 9700pro, Win XP PRO.
    First porblem I found is that if I set the controller on "DMA if Available" I'm not able to burn even a CD. Under Nero I get always the same errror: "Communication Failed", normally it happens from 1 to 5 min of burning, on every kind of support. I resolved by tunrning on PIO Mode4 but I can't understand Why I have to do that when with my old burners (HP DVD200i and LG 4020B) All worked Fine. I've updated my system with all the latest drivers with no results.
    Do I have to change the IDE cable? The original one is too short for me... I have a big tower, which kind of cable do you suggest (33, 66, or what?)
    Second Problem is that when I verify the CD burning at 24x with Nero I get always some "unaccessible file" errors, while if I try to open the unaccessible file I have no problems. I tried to burn on a CD RW at 4x and I got no errors.
    Third Problem...better... this is a question.
    HAS DRU500AX OVERBURNING CAPABILITIES?
    I've tried in every way to overburn a CD with 707Mb of data but I always get the Error msg "Invalid Parameter" !!! Nero says that DRU can overburn but I'm not able to do that.
    Can you help me? I'm really disappointed, I've waited 5 months for this drive and now that I had it I'm thinking to reinstall the LG that gave me no problems at all, doing always is work, slooowly, but olways finishing it.
    P.S. Now I've installed it on a P4 2.4, QDI Platinix MB, WIN2000 PC and it works very well.... uses DMA and doesn't give me any kind of problem with the exception of the overburning. But a friend of mine has the DRU on an a PC similar to mine and it works like a dream ..the only difference are WIN2000 and an ASUS P4S8X-X instead of P4S8X): I can't understand this strange behaviour...
    Regards
    Shotaro
  2. Dont know about the above, try a OS reinstall? (sounds like OS probs).
    As for overburn, it doesnt it.
  3. I have the same problem, it won;t biurn on DMA, it;s not an OS thing, but a hardware problem (obviously that extra x makes all the difference with your mates MB)! me and my mate bough on each, and I installed both, his works okay, and mine only in PIO mode too, which is annoying, as it takes too much CPU usage, and seesm a lot slower (won;t even read a CD in DMA mode, let alone write one)! Anyone else got a solution to this?
  4. Probably your motherboard doesn't like the drive in DMA mode. If available, when the system boot-up (POST, before going in Windows) check what the motherboard is reporting. You might see it as PIO and everything else is in DMA.
    No, it won't overburn.
