What is the right/compatible bitrate for AC3 for DVDs?
Basically what are the most compatible setting?
Are there any specs anywhere for DVD compatible AC3?
BeSweet seems to do 384 kbs. -
I use BeSweet for my AC3 encoding and use the 224K setting at 2 channels and have acceptable volume levels. Many posts have complained of inadequate volume levels esp. at lower bit rates. I do not know if this problem has been fixed. Experimentation is in order.
Curiously, adding gain does not seem to affect MY volume levels. perhaps I do not understand the concept. Normalizing makes everything sound the same. Again, my limited experience.
I do not think there is ONE setting for DVD compatibility. Just as in bit rate for video, the amount varies the quality. -
The DVD standard supports several different types of audio encoding standards at different bitrates. In regards to Dolby Digital, it supports anything from 64kbits to 448. 2 channel DD is almost always 192kbits and 5.1 channel DD is usually either 384kbits or 448kbits.
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 13:53 -
Bit Rate
By shapper in forum Newbie / General discussionsReplies: 10Last Post: 2nd Jun 2008, 15:04 -
Reducing bit rate of AC3 file of DVDs
By rock_king_my in forum AudioReplies: 9Last Post: 7th Dec 2007, 06:33 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 06:48 -
the right bit rate
By nojee in forum Video ConversionReplies: 5Last Post: 10th Nov 2007, 04:00
