I can paste from ChapterX to the right side of the window in VCDEasy chapters (right above the clear all button) but what is the next step? Can't get the chapters to function beyond this point. Thanks.
Click on the link...
https://www.videohelp.com/sefy/?id=chapters2.html"Don't tell me to go to hell when you don't know what heaven is." – Yohji, Weiß Kreuz
“No one has the right to take the life of another.” –Rem Saverem, Trigun
That's rather strange, if you can Paste, then Screen 3B should popup, the only time it won't popup is if you didn't copy the entire text correctly, and you need the Entire text to be in the clipboard
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Administrator Privilege to Run VCDEasy
By asifmcp in forum VCDEasy GeneralReplies: 2Last Post: 8th Jan 2011, 04:48 -
VCDEasy doesn't work in Vista...
By iThinkYouBrokeIt in forum Authoring (VCD/SVCD)Replies: 14Last Post: 26th Dec 2010, 20:20 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13
