I finally got my firewire card installed and am ready to do some capturing. I want to eventually move my video to dvdr with the least amount of loss from the original. Any recommendations on capture program and file type to export to? I will in the end be using Maestro to author the dvd, so the file has to be compatible with that. Should I export to mpeg2, avi or mpeg1?
Ok, from what i've read it seems that dv-avi seems to be the best format, but when I tried importing the avi into Maestro it comes up with a media detection error. Can anyone recommend some settings that will allow maestro to accept an avi? Or does Maestro even accept avi format??
I never used Maestro, but I've used Ulead DVD Workshop and DVDlab.
Here's what I do.
1 Capture DV AVI
2 Edit the AVI with Premeire (but you can use any video editor)
3 Output the edited video to DVD 720x480 - CBR 8000 kbps. 384 kbps Mpeg audio.
4 Import the Mpeg-2 file into DVD authering program and create DVD files.
5 Burn DVD with Nero or RecordNow Max
I usually get a little over an hour video per dvd.
Hope that helps.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
I just capture to DVD complient mpeg2 then use NeoDVD Plus to add a menu and chapter points and burn a DVDR.
Convert DV type 2 to type 1? Or is there an app that will correct sync?
By Colmino in forum Newbie / General discussionsReplies: 7Last Post: 20th Dec 2022, 22:24 -
Export DV type 1 with Virtualdub?
By Asterra in forum Video ConversionReplies: 1Last Post: 16th May 2011, 04:10 -
Export Video Header
By BRotondi in forum Newbie / General discussionsReplies: 3Last Post: 18th Jan 2011, 16:35 -
How to convert a trp type file to Mpeg2 type?
By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 16:59 -
Blurry video on export
By beckerss19 in forum Video ConversionReplies: 25Last Post: 1st Oct 2010, 14:58
