  1. I'm trying to make chapters for a movie and the max allows only 2 chapters max. Other movies work fine but this one isn't. Can some help? Thanks...
  2. Could you post some more information about what you are doing ? What movie ? Is it Divx, Xvid etc ? What programs are you using ? Do you get any error mesages ? The more info you provide the more chance of getting an answer. 8)
  3. I'm using VCDeasy. I'm burning an mpeg-1 formatted 1:00 hour movie. Like I said before, it will allow other movies more chapters to be inserted and only 2 with this for some reason. I've tried multiplexing it, but it didn't work.
  4. Does VCDEasy allow you to apply the chapters ? I've just applied the chapters and it allows me to put them every minute on an MPEG1 file.
    I haven't burnt it to VCD to check because my DVD player is knackered.
    What clip are you trying to add chapters to ?
