I have a 2.66GHz Pentium 4 with 512MB of PC1066 RDRAM and use a 16X Samsung DVD-rom drive when converting my DVD-9 to DVD-5 using DVD2ONE. My computer gets REALLY slow while running DVD2ONE to the point where it takes about 30 seconds for a program to pop up. Is this normal?
Why would you want to open another program while you're running DVD2one? Your CPU is probably running at 99% while rencoding. The best thing to do is turn off all apps and leave the computer alone until it's finished.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Yes DVD programs that convert are VERY processor intensive. If you had 3ghz it would use all of that also. Its not unusal in the least. Its also why I own more then one machine, cause between that and gaming you can never have enough.
Ripping DVDs to my computer
By sd2005 in forum DVD RippingReplies: 10Last Post: 1st May 2012, 14:32 -
Video slowdown after converting.
By JackDanielZ in forum Video ConversionReplies: 4Last Post: 11th Apr 2012, 04:07 -
Ok, best tool for converting dual layer dvds to single layer dvds is?
By burgkev in forum Authoring (DVD)Replies: 5Last Post: 25th Aug 2008, 01:02 -
Burner Slowdown
By Mitchum22 in forum DVD & Blu-ray WritersReplies: 13Last Post: 28th Jul 2007, 00:01 -
A/V lag issues with code 1 (NTSC) DVDs normal?
By FiD31 in forum ffmpegX general discussionReplies: 3Last Post: 24th Jun 2007, 05:38
