  1. Ripping my DVD's to the hard drive and leaving them as VOB MPeg2 files and would like to know how to play these files without getting the "hiccup" between the VOB's if I use a player like PowerDVD. In other words, if I play the VOB's from the hard drive, the screen will pause between the ending of one VOB and the beginning of another one. Is there a way around this?
    Thanks!
    Foochey
    "Before you give somebody a piece of your mind, make sure you can get by on what's left"
    -S
  2. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    when ripping in DVD decrypter set it to no file size restrictions instead of auto. the auto will chop up every 1gb, the no restriction will be all one .vob file.
  3. Thank you SO much for the great info!! That worked beautifully using Smartripper!!! Exactly what I was looking for
    -F
    -S
    Have you tried play in dvd video mode? by open the video_ts.ifo file instead of playing the vobs.
