hey there...
I'm trying to convert the movie Spirit from DVD to VCD and I'm getting this error (error code 2) about 1/4 way through encoding with Flaskmpeg. Can it maybe not be done, or am I doing something wrong. I've tried it about 10x already and getting really frustrated.
Spirit, is able to be a ripped and copied for your own use. I just did that movie a couple of days ago and it turned out fine. I got no errors with it. I don't know what programz you are using to do it with, but I used,Smart ripper,dvd2avi and finally tmpgenc to convert to vcd.or in my case vhp which put the movie on one disk.. This movie turned out great. You might be running itnto a bad video block, that isn't able to be read. Sometimes I have that problem. If you use one of the programz I use ,it tells you what the error is on the screen and why. It has been solved by me by using a different copy to start the process with. I am not advocating ripping for anything other than your own personal use though.
ModartistModartist
Some are born to rule the world. to live their fantasies.
While most of us just dream,
of what we would like to be. -
use a different ripper. I have backed up this movie with no problem. Clean the DVD. Try DVD2SVCD as it is a one click solution (or try another all in one converter.
Spirit sniper (ts sniper). problems with editing T.S files with this app
By talx in forum EditingReplies: 6Last Post: 4th Jul 2012, 04:24 -
Protecting a dvd from being copied
By arnold.iceman in forum Authoring (DVD)Replies: 4Last Post: 14th Aug 2010, 10:12 -
Copying a copied dvd
By Angel87341 in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2010, 13:56 -
Can a music CD be copied into a DVD?
By coody in forum AudioReplies: 6Last Post: 13th Oct 2008, 18:32 -
how do i prevent my dvd from being copied
By kareen_630 in forum Newbie / General discussionsReplies: 213Last Post: 6th Jan 2008, 09:16
