Can anyone please help?
My PC keeps freezing everytime i try to convert my video footage to DVD.
I use pinnacle studio DV video capture card, pinnacle studio software, unlead dvd, TMPGEnc all of wich freeze. the video footage is about 80 mins with and estimated dvd file size of 3gigs. I have a 2 gig Athlon processor and 2 80gig hard drives as well as over 500 megs ram.
Please help
Sherilee Gould
Hi there,
What version of windows do you use? (XP,2000,98)
You could try downloading and installing the latest drivers for your video capture hardware and your computer's video card.
Also, running microsoft windows update by going to http://windowsupdate.microsoft.com may help you. This will update your system files and possibly correct some problems with your computer.
Also, if you are creating one big file (over 2gb) you need to be running Windows XP/2000/NT and using the NTFS file system, otherwise individual filesizes are limited to 2gb (FAT).
If you need help with any of the above just say, I can provide details,
hope this info helps,
Clint -
Hi Clint,
Thanks for the prompt answer. I am currently running win98 but i can upgrade to XP. I regulary check for updates to all my programes and as far as im aware they are all up to date.
Its just so frustrating, but i'll try the xp and fingers crossed.
Many thanks
SherileeSherilee Gould -
Sherilee,
I think you'll be better off with XP. It handles large files much better than 98. Make sure to format with NTFS and try to capture to seperate HDD. Also defrag often, it helps move things along better.
Good luck!Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
What causes computer freezing and slowness?
By Obamargarine in forum ComputerReplies: 13Last Post: 19th Apr 2009, 22:44 -
Computer Keeps Freezing
By Squid_uk in forum Newbie / General discussionsReplies: 14Last Post: 11th May 2008, 07:43 -
CoreAVC freezing computer randomly
By silverwolf0 in forum Newbie / General discussionsReplies: 1Last Post: 21st Dec 2007, 03:44 -
Asus DRW-1814BLT Freezing Computer While Working
By mightymo77 in forum DVD & Blu-ray WritersReplies: 5Last Post: 1st Nov 2007, 10:54 -
Computer Freezing up
By ruknabard in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2007, 17:52
