does anyone know of a program that can extract an ac3 file from an avi that does not change the header to wave?Ive tried besliced but there seems to be some compatability issues with xp(ive changed the compatability mode but it still doesnt work) ive also tried ac3 fix but it just tells me there is an error and it needs to close! Ive extracted using goldwave whitch just converts it to a full wave file and ive also extracted using vdub but it gives a wave header to the file that i cant change. any help would be aprecciated as im going bald!!!![]()
I have winxp and it works fine to use virtualdub and beslice(be sure to extract all besplit files to a folder and run beslice) or ac3fix. Are you sure it is ac3?
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 21:53 -
Convert AVI with H264 and AC3 to AVI with XVid and AC3
By ashwin.terminator in forum Video ConversionReplies: 4Last Post: 26th Jul 2009, 11:17 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
converting mpeg2/ac3 and avi/ac3 to avi/lambmp3
By corumz in forum Video ConversionReplies: 2Last Post: 17th Sep 2007, 09:32
