I'm trying to convert some video tapes to DVDs. When i just capture the tapes to .avi files and then use premiere to encode them to mpgs then use IFOedit to make the VOB files, everything goes well, but the video looks interlaced and low quality.
When I use AVIsynth and VirtualDub to post process the .avi files, they look much better, but then I encode them to mpgs and create the VOBs the same way, then video becomes glitchy. I get it breaking up into large blocks, or an occasional stripe for an instant, and the sound sometimes goes out of sync.
I tried turning the bitrate down from 8000 to 6000 in the premiere encoder, but I still get the same results. My equipment is an athlon 2400+ with 512 MB ram, Pyro A/V link capture box, and sony drx500ulx DVD writer.
Any advice is appreciated. It is frustrating to spend hours encoding something to have it come out glitchy.
Yoyocafe
Results 1 to 1 of 1
Need Help Converting VHS to DVD - Diamond One Touch Video Capture -
By DanteCrowley in forum Capturing and VCRReplies: 5Last Post: 20th Dec 2011, 19:09 -
AverTV HD DVR video glitches
By FTW in forum Capturing and VCRReplies: 8Last Post: 2nd May 2011, 12:40 -
Converting VOBs from a DVD to a single AVI
By aln688 in forum Video ConversionReplies: 25Last Post: 6th Apr 2010, 08:34 -
Difference between encoding and converting video
By nb23 in forum Newbie / General discussionsReplies: 6Last Post: 21st Sep 2009, 00:13 -
Best Practice for Converting VOBs for Editing -> DVD?
By ehmjay in forum Video ConversionReplies: 4Last Post: 7th Jun 2009, 12:46
