Righto,
Tried using CCE SP and converted my .avi files to two streams, MPEG-2 video .mpv and the audio stream as .mpa
Now, aI can play either the video stream or audio stream, to check them, but, what player will play the video stream and if the .mpa audio stream is present play that as well, so that you can check that the audio/video are in sync
I tried this to try and see if I can stop the "jumping" when burnt to DVD-R using an MPEG-1 or 2 program/system stream
Also, when burning these streams, am I correct in assuming that the author software will correctly author these, or does it need another step, so when burnt to DVD-R I end up with the audio stream in the correct folder and the video stream in the correct folder, so I can burn them using Nero DVD, which I'm trying out instead of ULead MovieFactory
Even better, will ULead MovieFactory accept these file sdirectly, without insisting on converting them again, so adding to the conversion/burn time, and making the end quality even crappier
Results 1 to 1 of 1
wmp win7 not playing certain mpeg1 files, gspot info included
By Rudyard in forum Software PlayingReplies: 6Last Post: 7th Jan 2011, 03:53 -
Sound problem while playing mkv files
By shorto in forum Newbie / General discussionsReplies: 1Last Post: 21st Jun 2009, 05:02 -
can't play .mpv files with sound
By gbabione in forum Video ConversionReplies: 10Last Post: 23rd Nov 2008, 12:10 -
AVI Files only playing sound, not video
By Choochi in forum Newbie / General discussionsReplies: 4Last Post: 11th Jul 2008, 15:42 -
No sound when playing AC3 files...
By GangstaRap in forum AudioReplies: 1Last Post: 10th Feb 2008, 00:21
