I recently tried to watch Monsters Inc on DVD with a progressive scan DVD player and THX certified $100 Component connectors into a Sony WEGA KV-34XBR800 HDTV and it looked like crap!!! Tried Interlaced mode as well and nothing cleared up the image......most of the picture was perfect but there were a lot of colors and shapes that flicker like crazy and render it unwatchable!! Any suggestions?
Closed Thread
ViperJPB -one thread on this subject is enough ..
mysticgohan17 - what do you mean CGI is not as good as real film ? much of "real film" IS CGI ... there is no diff. in terms of quality of resolution in most cases ... well there can be if rendered at to low a res or color , but thats not the case w/ monsters inc .. at least not the org. render ..
i wonder if they used a film scan of monsters inc instead of the source files which would be cheaper but poorer quality ..
Are there progressive scan DVD discs??
By seekt in forum DVD RippingReplies: 33Last Post: 21st Oct 2009, 13:52 -
Progressive Scan for DVDs
By KayAt in forum Newbie / General discussionsReplies: 9Last Post: 25th Nov 2008, 22:30 -
Progressive scan problem
By Deaner777 in forum Authoring (DVD)Replies: 0Last Post: 28th Jul 2008, 16:23 -
3:2 progressive scan pulldown support.
By wasimismail in forum Authoring (DVD)Replies: 47Last Post: 11th Jun 2008, 22:51 -
Confused about progressive scan
By Xoanon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 14th Jun 2007, 13:28
