I am using Ulead DVD Workshop and I want to have some background video to use in my menus. Something like Ocean/wave, sky/cluds, etc.. that move and can be repeated. I have seen http://www.animationsforvideo.com/html/time_image.htm and http://www.corporatemotion.com . I was hoping there is a free resource out there where I can download stuff like this.
Evan
Results 1 to 15 of 15
I've looked for free stuff myself without success. There are some CD's on Ebay that seem fairly reasonably priced (e.g. $25 or less) for a larger number of motions than seems to be on the expensive packages. I do have a some Ulead motion background CD's a got at a show. The price was okay, as the show deal was buy one get one.
I don't use Ulead (or even have a DVD burner for that matter!)
.. but what format do the clips have to be in for you to use them?
The first link that lurker gave says that the clips are all mov's
If the format's pretty flexible, can't you capture or convert something suitable?
cheers,
mcdruid. -
Yeah. U can import movs or any other format in there. Obviously, I am looking for something high quality. As for capturing or converting, I wouldn't know where to start. I don't want to just go to some movie or show and rip some content from it.
Lurker -
A couple of suggestions for you:
1. Ulead COOL 3D STUDIO is a new product that features some cool animated backgrounds that can be used as MOTION MENU BACKGROUNDS:
http://www.ulead.com/c3ds/runme.htm
2. Check out the samples on the Ulead Pick-A-Video PRO site:
http://www.ulead.com/pav_pro/runme.htm
These are not free, but they're reasonably-priced and the quality is excellent.
If I think of some more options, I'll post again.
Jerry Jones
http://www.jonesgroup.net -
main concept has a bunch for free - free download or for shipping only they will send you a bunch of cd's
check on the main concept web site -
High quality is a hangup with my solution, but it is cheap and it works.
I discovered that my Ulead Video Studio 3.0 program, left over in my CD-ROM library for many years now, will import and play a standard GIF file from the net. I will use that program to create a short AVI, then I will import that AVI into Adobe Premiere. Next, I shrink it and fill in the background with the foreground color, or make it transparent using Chroma Key. After that, you must use your imagination, but it can be expanded, shrunk, moved and faded. I'm guessing that you can pull off some effects like Tim Allen used to use in his Home Imprvemnent Show with those little corner animations"Never doubt that a small group of committed individuals can change the world. In fact, it's the only way the world ever has been changed."
Frank -
The Tinderbox 'T-Sky' plugin for AAFX is also fantastic for generating moving sky footage, but it ain't cheap...
Arky ;o) -
This won't be much help to you, but I am a big fan of BBC nature documentaries, so I always extract snippits of them from my collection for a few seconds of scenic footage.
PS
DVDWS seems to only seems to allow 5 seconds of motion footage
on a menu. Anyone figured out how to make it do more? (eg. 30sec)The glass is neither half-full, nor half-empty.
It is simply twice as big as it needs to be. -
I noticed that too using the demo version. Once I got the non demo 1.3, it gave me any amount of time I wanted.
Lurker -
I'll pretend I didn't read that!!Originally Posted by nerdboy69
to get any of the software above for free just <Edited - do not promote warez - see rules>
Sometimes, you just have to laugh - it's a downright obligation!Originally Posted by energy80s
You could also leave your miniDV cam on a tripod, pointed at the sky, on a sunny day and use that for background footage. Obvious but no less effective for it. In such instances, it is often worth unnaturally altering the colour balance, to suit your artistic whims, since it can give a more 'solid' background to the overlying buttons.
Arky ;o) -
Pinnacle Studio 8 comes with some mpeg files for motion video. They can be used with other sw as well. they're simply some short mpeg clips. I've used a couple of them and they're quite nice. I don't know if a demo version is available or not. If you know somebody who has that sw, maybe he'll let you copy them, or e-mail them to you. They're very small files.
content based video analysis using motion detection
By Rimaz in forum ProgrammingReplies: 1Last Post: 4th Apr 2012, 11:30 -
3D dvd content - convert to Blu3D content
By Smells_Like_Feet in forum Authoring (Blu-ray)Replies: 19Last Post: 18th May 2011, 08:52 -
Does Tmpgenc Authoring works 4 support motion background menus?
By perfection in forum Authoring (DVD)Replies: 1Last Post: 10th Mar 2011, 03:35 -
Motion Background Questions
By opentone in forum EditingReplies: 5Last Post: 13th Feb 2009, 19:52 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 21:11
