I guess I've been lucky and have experienced only two events of audio sync. problems in all the caps and DVDs I've made.
And both times have been when I've used Womble(version 3.13) to trim the very 1st few seconds off of a(5mbps/CBR) Mpeg-2 file before authoring it into a DVD. I do that by Marking-In the place where I want my video to start(after the part I want to remove) and Mark-Out the end of the video. And then I click SAVE and "name" the saved file and let Womble process the saved file(them I import the trimmed clip into my authoring program and burn it).
Does Womble have a problem with editting out things like this? Am I doing Womble right?(using the wrong steps/procedure in Womble)?
What can I do with Womble that I'm not doing now to illiminate the audio sync problem that results in the saved video file?
Results 1 to 1 of 1
"Signature"......
I use a Dazzle capturing system that Only lets me capture into Mpeg. So that is all I work with. I never do any DV/AVI video.....
Noob needs help trimming, splicing, audio with AviSynth
By PapaDmitry in forum EditingReplies: 39Last Post: 6th Jul 2010, 09:53 -
Trimming the audio to go along with the video cuts in avisynth?
By mt123 in forum Newbie / General discussionsReplies: 0Last Post: 10th Jan 2010, 03:23 -
Problems with womble dvd editor
By auto7890 in forum EditingReplies: 3Last Post: 1st Sep 2008, 23:21 -
Trimming then extracting audio
By chrishallowell in forum EditingReplies: 3Last Post: 2nd Nov 2007, 00:29 -
Audio sync problems
By jelockwood in forum ffmpegX general discussionReplies: 1Last Post: 30th Jul 2007, 12:03
