i have a dvdr, can i make a straight copy from it with a dvd writer?
... to elaborate, you can use DVD Decryptor to read an ISO image and then write it back - alternatively, you could probably just use the software that came with your recorder or any other burning software to do the job as the disc is not copy protected if it's on a DVD-R.
In fact if you use your burner software it's probably a two click job - like clicking on "disc copy" and clicking "write".
Be warned that if you're using Nero, for some reason disc copy seems to make the copy "grow", so if the DVD-R you want to copy is close to the maximum capacity it might give you problems doing a disc to disc using a DVD-ROM and a writer.
You can get around this by selecting the writer as the source drive, using that to read the disc buffering it to the hard disk in your PC, and then swapping the "original" for a blank.
Job done. -
Im just about to copy my first dvd
Do i need to set my dvd writer to a specific region? if yes, do i need to change it every time i copy a different region dvd?
You need to change region everytime you insert a new region DVD.. but you can change this only 4 time so be carefull !Originally Posted by filefeeder
Ehrm....
You DO NOT need to set the region if you burn a DVD-R. First of all a DVD-R (as source in this case) is most likely region free, if the source IS region protected DVD-Decrypter will surely remove this. You only need to set the region of your DVD-player/recorder if you want to PLAY a specific region. If your player is set to Region 1 and you want to play region 2 dvd's this requires you to change the region setting of your dvd-player/recorder. THIS you can do only 5 times (Unless you have/make it region free)
Greetz,
pSyChO dAdThe difference between genius and insanity is only measured by success !
Straight conversion to MP4
By DominionZA in forum Video ConversionReplies: 9Last Post: 20th Apr 2012, 07:43 -
flv straight to dv?
By ShaneJensen in forum Video ConversionReplies: 1Last Post: 26th Aug 2010, 00:46 -
Ripping straight to mpeg
By NurEinTier in forum DVD RippingReplies: 7Last Post: 22nd Nov 2009, 10:11 -
burning straight to disc
By Tirion in forum Capturing and VCRReplies: 5Last Post: 10th Jun 2009, 09:32 -
Straight Burn to DVD
By lookingtoburn in forum Newbie / General discussionsReplies: 2Last Post: 21st Jan 2009, 19:22
